z-5500 question
13 Jan 2006
Wigan
hey
has is it possible to take the front grill off the sub??
i had the screws out but it wont budge, dont want to put to much force into it incase i damage it
any1 managed to get it off??
thx
joker
i want to spray something on the metal grill that covers it and dont want to do it while it on sub, also want to see what it like without the cover
with the z-680 the grill is only glued on and should be the same for the z5500.
Use a tourch to find out where the grill is glued on then take those big paper clips and hooked it through the grill for each part off the places where it is glued and pull gently. Dont rush it, Im sure it will come off with lightly tugging at the glued parts. Hope this helps mate?
I havent taken my cover off, I came across someone who had in a different forum
Apparntly some people thinks it looks better without the grill,, but ive seen pictures of the z-680 and z-5500 without the grills, and I think it looks ugly.
Anyay I need the grill on mine so I dont kick it cos its under my desk right by my feet. It also makes a great foot stool. :D
The Z-5500 sub looks like it has big bolts holding it on, but it could be just for display purposes. I need to take it off too to give the grill a clean, spilt a drink and it's kinda stuck to the grill
ITS GLUED ON, just do what I said and it will come off
excellent thx for help i took screws out but didnt want to pull it too hard, cost me a lot of penies :P
ty peeps !
joker
xx
