OK have been reading up how the NF200 chip works on Z68 (P55, P67) and I still can't get my head around it.
All the above chipsets have 16 pci lanes on the cpu and 8 lanes through the southbridge.
Boards excluding the NF200 chip either use the full 16 lanes on a set up but would split them into 8 x 8 for sli/crossfire. All basic stuff.
The NF200 claims to add 32 lanes, my understanding of how it does this is by multiplexing the cpu lanes, basically multiplying them by two. This gives boards with the NF200 the ability to run dual card set up with full 16 x 16.
However the GPU must communicate with the cpu to output onto a display. The CPU on these chipsets can only connect with any gpu devices with a maximum of 16gb's as the lanes are actually on the chip. Therefore how can two full 16 x 16 cards (with max throughput of 32gbs) communicate at full bandwidth when the connections has to be physically limited by the links available on the cpu?
I;ve read lots of explantions but most are either confused or unconvincing. Surely any devices connect to the cpu in these cases has to be limited to the links on the cpu?
After all, the 2x16 lanes are only x16 up to the nf200 chip. This would go the same for a board claiming Gen 3 support but may have lane multiplexers which may not support it so only some configurations may support Gen 3.
