I was planning on getting an Asus Xonar Essence ST (PCI) for my new build, as opposed to the Essence STX (PCI-e), as it seems from posts I read on an a well known audiophile forum that the consensus is that the ST sounds better (it also has good reviews on here), primarily it seems because it has the CS2000 chip which is supposed to help with jitter. (I think it was also cited that by using the ST, you can keep it away from the GFX card).
Now, I note from a post on here by stulid that it's best to use a PCI-e card on Z77 boards because of potential issues and compatibility problems with PCI on these boards. (Planning on getting an OC bundle with the Asus P8Z77-V).
I also did a quick web search on the subject, and only managed to find a post on the Cakewalk forum where someone mentions as well that there can be issues with PCI cards on newer motherboards as they use a bridge from the PCI-e bus.
So I was wondering, are the compatibility issues more prevalent with certain types of, or make of card on Z77 boards?
Has anybody here used the Asus Xonar Essence ST on a Z77 board with no issues?
And is it worth taking the risk and going with the ST?
