Z87X-OC Performance issue (Graphics related)
29 Aug 2010
Cornwall
OK, bit of background.
I bought my 7950 back when I had my 1055T chip. Seemed to work fine. Then got a 8350, seemed to work fine.
Then I build basically a new PC using a Gigabyte GA-Z87X-OC motherboard and 4770K CPU. I re-used the 7950.
Running Heaven 4 using the setting in the benchmark thread my scores varied between 650-750 (ish). This was annoying.
I then bought a couple more 7950s when they were on offer. I wasn't going to use them in this machine, but since they were basically the same card I decided to test them in the machine, replacing the existing 7950 one at a time.
The Heaven scores were much lower than the other 7950. Just at the start the first 10 seconds or so, usually run at around 20fps. These cards were running at 5-10fps. I've since put them in the other machine and they seem to run fine, so I don't think it's the cards.
I've now put a GTX 670 in the machine instead of the 7950 (uninstalled drivers etc.) with the intention of going SLI. However, I'm once again getting issues. The starting sequence of Heaven 4 is again running at around 9fps.
I've tried re-installing all the motherboard chipset drivers but it hasn't seemed to help.
I'm not even sure if it's a motherboard or graphics card issue. The number of graphics cards I've tried is making me think it can't be them.
Any ideas?
You tried setting gen3 mode rather than auto?
Take BIOS screenshots with f12 key and Usb stick,won't lose your settings then
These X series BIOS have a lot of work put into them by overclocking pros, they really are well made and well tested to extreme levels.
The options available are fantastic.
Remember that you have a dualBIOS switch, so have your safe F6 BIOS on one chip and mess around with X07 on the other chip? so a 24/7 and extreme option at the flick of a switch so to speak:)
