Zacc: Project Fourty Five Quid
good morning, another one of my asus boards seems bricked with uncontrolable bsod (tried with a athlon) i will mess about with ram slots.ect but i think the boards gone. after al, this is my 7th broken asus board in the last 12 months
edit: ram slots just made the issue worse
going to try the board on a friends cpu aswell but im pretty sure it may need a reflow :L
Chances are it's broken because you keep getting them second hand. That isn't meant in a harsh way or anything, however, it's not like you hear hundreds complaining about their Asus Mobo's dying...
You tried resetting the CMOS? Might be that your overclock wasn't liked...
kd
kd
yupp done allot to try and stablise the system, i have a grudge against asus, not everything i buy is second hand but from what ive seen that on the lower end boards (£100-ish range) that there are a lot of design faults and they always end up breaking. weather there second hand or not shouldn't really make much of a difference, other than the asus boards there was a 15 year old dell working perfectly, a intel 775 board and a asrock 775 that have died on me, it just shows something about there build quality and lifetime, if most other things ive had in the same joblots.ect have worked.
actually i praise some of asus higher end boards, i had a am2 board some mn32 sli or sumink along those lines that had been hugely mistreated the wifi card in it had a rusty heat spreader/cover on it to give you an idea, and that seemed okay, for about maybe 3 hours before exploding on me due to age, witch was only about 3 years.
honestly it wouldn't really bother me zzzac, as the chip alone is worth more than you bought the pc for :p
yeah, im not really that bothered, bit annoying but im advertising the chip on the bay for £80 witch is the going price on ebay, so, and i got a case, a cooler and a board that will probably go to a mate in an atpemted repair, not sure anything will work although, im actually quite tempted to switch cases from my stacker to the thermltake but im not sure i can be bothered
I have a p8p67-le, it's the lowest end p67 asus board iirc and it's actually quite good, the only thing that annoys me is the lack of right angled sata slots
acidently snapped a sata port on my old am3 board due to it not being right angle and flexing a lot, i instantly reinforced teh rest with superglue.
infact i recall specificly not buying a new asus board for my sandybridge just because of past experience.
I'd still go with a z68-ud5 probably, as they are some of the best looking motherboards you can get and they're a good price :) but why can't gigabyte make a z68-oc?! :mad::mad:
trolol, well this was a fun project, i sold the phenom for £83 posted one aby, and that was the price of a new 955 when ocuk were stocking them :D
