- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
We currently have the lowest price in the UK on this cooler. Sporting a great copper flower design featuring a built in fan controller and provides excellent performance in cooling. To top the deal off we have also thrown in the Socket LGA1366 (Intel i7) and the Socket LGA1156 (Intel i5) brackets in for free.
Zalman CNPS9700-LED CPU Cooler with i7 and i5 Bracket (Socket 754/939/940/AM2/LGA775/LGA1156/LGA1366) @ £17.99 inc VAT
To look at the cooler, you would think the CNPS9700-LED is exactly the same as the hugely successful CNPS9500-LED. But on closer inspection, you will soon notice that the cooler is about 20% bigger! Instead of using a 92mm fan like in the CNPS9500, the CNPS9700-LED has a huge 110mm fan! The larger size of the cooler gives both an increase in airflow (due to the fan), and an increase in surface area (due to the fins). In combination, this gives unbeatable cooling performance. The cooler is multi-socket compatible, and comes not only with a Fanmate2 fan speed controller, but also Zalman’s well-respected premium heatsink compound, ZM-STG1.
- Socket Type: AMD 754 / 939 / 940 / AM2 / Intel LGA775 / LGA 1156 / LGA 1366
- Dimensions: 90mm x 124mm x 142mm
- Fan Connector: 3-Pin
- Fan Speed: 1250 - 2800 RPM
- Noise Level: 19.5 - 35.0 dB
This bundle consists of the following items:
1 x Zalman CNPS9700-LED CPU Cooler (Socket 754/939/940/AM2/LGA775)
1 x Zalman ZM-CS4A Socket 1366 Clip Support Kit
1 x Zalman ZM-CS5B Socket 1156 Clip Support Kit
Only £17.99 inc VAT.
ORDER NOW
http://overclockers.co.uk/showproduct.php?prodid=BU-000-ZA
ORDER NOW
