I'd set them up somewhat the same as I posted near to the top, works well for me.
This is my current set-up which I find works well, although I have ditched the fan on the side panel as it was very noisy there.
I have also cut the mesh off the fans as it improves airflow and makes them quieter.
And a 140mm Apache Black fan in the front, which shifts a lot of air. That's the only extra fan I have and it's plenty
hi andy, do you think I should I should install a corsair AF140 fan in the fornt of my case instead of a SP120
Looks good. How do you find the side fans? I found mine to be very noisy through the grills, although might be better now I have a fan controller.
The wires at the back are a squeeze, I spent some time organising and cable tying them up, doesn't look pretty but the panel goes on and it looks of from the front
Just a quick pic of how mine is at the moment. Excuse the dust, I removed the fan filters for maximum airflow as the CPU and GPU are running flat out 24/7 F@H.
