- 10 Jun 2010
- Scotland
OK. So I built up a rig today using the Zalman Z9 Plus case. All went well as per usual. Fired it up, installed Windows.
Only problem is the fan controller doesn't seem to be doing it's job. I'm turning the dial, but nothing is happening!
I know the fans are connected properly as they are powering up and spinning away nicely. However, there speed doesn't change in accordance to the dial.
Have I missed something here? Is it a faulty controller? Anything I should be checking or looking for?
I googled the issue and no one else seems to mention it.
Cheers for any replies.
