I recently got bought a Zalman Z9 Plus case from overclockers as a present.
I switched all my components over the the Z9 in the hope of an easy install to get it up and running.
Went to turn it on, and nothing. Not an inch of power.
I finally wittled it down to the Z9's power switch being faulty, as I am able to power the computer up from my old cases power switch.
Is there any fix I can do? Or is it worth just sending it back for a new one?
Cheers.
Cheers.
I really don't want to return.
