Zaward 120mm/140mm Fans - price drops
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey all
I have priced dropped the Zaward fans whilst current stock lasts.
With prices starting at only £6.98 inc. VAT your system can be cooled better and more efficiently. These fans offer excellent airflow and low noise levels due to the Golf Ball dimple design.
Zaward Golf II 140mm x 25mm Fan - Black @ £7.99 inc VAT
With unique patented golf dimple blades, these fans can reduce noise levels by up to 15% and provide high aiflow for excellent cooling performance.
- Unique patent Golf dimple blade reduces 15% noise level at the same RPM & airflow
- Low Noise level from 10~20.8dBA depends on fan speed
- Long life expectancy of 60,000 hours in 40 degree C
- It increases fan's efficiency and reduces current consumption
- PWM function supported, starting at low speed minimizing with very low noise level without reducing efficiency
- Dimensions: 120 x 120 x 25mm
- Fan Speed: 900 RPM
- Air Flow: 62.14 CFM
- Noise Level: 10 - 20.3dBA
- Life expectancy: 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 140mm x 25mm PWM Fan - White @ £7.99 inc VAT
- Low Noise level from 10.1~20.3dBA depends on fan speed
- Dimensions: 140 x 140 x 25mm
- Fan Speed: 300 -1200 RPM
- 74.14 CFM
- Noise Level: 10.1 - 20.3dBA
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 140mm x 25mm Fan - White @ £7.99 inc VAT
- Unique patent Golf dimple blade reduces 15% noise level at the same RPM & airflow.
- Low Noise level from 10~20.3dBA depends on fan speed.
- Long life expectancy of 60,000 hours in 40 degree C.
- It increases fan's efficiency and reduces current consumption.
- 62.14 CFM
- Noise Level: 20.3dBA
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 120mm x 25mm PWM Fan - Black @ £7.99 inc VAT
- Fan Speed: 300 - 1300 RPM
- Air Flow: 56.05 CFM
- Noise Level: 10 - 20.8dBA
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf II 120mm x 25mm PWM Fan - White @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Blue / White @ £7.99 inc VAT
- Sleeve bearing design extends ultra long life and enables lower noise level
- 7 dimple blades raise airflow and air pressure at the same noise level
- Able to convert small 3 pin to big 4 pin 12V input connector
- Fan Speed: 1200 RPM
- Noise Level: 17dBA
- Aitr Flow: 48.48 CFM
- Life Expectancy: 26,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Blue / Blue LED @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Red / White @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - Clear / Blue LED @ £7.99 inc VAT
Only £7.99 inc VAT.
ORDER NOW
Zaward Golf 120mm x 25mm Fan - White @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Zaward Golf 120mm x25mm Fan - Black @ £6.98 inc VAT
Only £6.98 inc VAT.
ORDER NOW
Not in the performance, but the pricing is 20%-25% cheaper than the Akasa Apache fans :)
That said, under load don't the stock coolermaster fans match all the fans?
Also the coolermaster fans are apparently quieter.
And being stock fans, presumably they came with whatever they were testing the fans on. So they'd be free. :)
SSssshhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
No-one was supposed to notice!
Silly review - any decent ones out there? ie Ones that don't give a 5star rating for something thats noisier and more costly than the stock CM fan? :rolleyes:
I've used plenty of stock Coolermaster fans in the past (and present) and I've always been very impressed how quiet they are (even at full load). They really cannot be faulted in my opinion.
Got one running in tandem with my Xigamatek thats rated at <18dBa - it's quieter than that!
- 74.14 CFM
- 60,000 Hours
Only £7.99 inc VAT.
ORDER NOW
Is this white 140mm PWM version coming back at any stage soon?
Noctua's market as patented golf ball design, so which is "unique"? :p They are both priced similarly and have similar specs too, well they should do considering they employ the exact same design.
