Zero intake fans
1 Dec 2011
Hey guys.
I have a GPU only loop, and just upgraded from a 360 to 360+200.
I got a good drop in gpu temps but a big increase in CPU as the new rad was blowing hot air into the CPU air cooler. I have turned young the fan on the new rad so now all fans are exhaust.
This has sorted the warm CPU problem but GPU temps are not as good as they were.
Any ideas?
LOL You have a 360 and a 200 JUST for a graphics card? What?
I have a 140 and a 360, I'm running CPU + GPU, still have room in temps to run another GPU if I really wanted.
I think you are a bit misled if you think you need 360+200 just for a GPU, you can run CPU + 2 GPU's off that.
Gpu temps are around 50. But the water is at about 38, which means CPU will be at about 60. That's not even an improvement from my air cooler.
Using a HWL GT Stealth 560 Rad[32mm thick] low 900rpm fans at ambient of 23'c, CPU i7 920:4.2ghz CPU cores never go over 60'c / GPU Toxic6950>6970 - 950/1350 - 50.
You don't say what kind of case you have but there is nothing wrong with both rads as exhaust.
As long as the air isn't being recycled outside your case, and you have some vents to let fresh air in (ideally opposite the rads)
And air cooled cpu and watercooled GPU's always made better sence to me
As graphic cards don't have the room for large tower heatsinks.
but it's not the 'normal' way to do it - so expect some flack
