Zombie Maxtor!
23 Jun 2004
Macclesfield
Well, raised from the dead anyway :)
Had this 160GB Maxtor diamondmax 9 which SMART said was dead and should be replaced, had loads of bad sectors. I figured if it were heavier it would be useful to prop the door open, but I laid my hands on this HDD Regenerator V1.51 program so ** I'll give it a try.
Well it took 2 days :eek: to run, it found some 45,000 bad sectors, and it said it 'fixed' them all. Sure enough, booting with it attached it passes the SMART init with no complaints. Did an in-depth SMART analysis using SpeedFan and it confuses the report :) It says the SMART record indicates it was a bad drive, but puzzlingly it's OK now.
I'm just running the Maxtor utilities boot disk now to see if I can reset the SMART record. I don't think I'll be storing anything critical on it, but if it's still OK might shove it in the kid's PC...
Behemoth said:
Cool, is that app freeware ?? Might recover one of the drives I got here which I'd like to use for non critical stuff.
I just looked - No it's not free, but there is a demo available. Dunno if it's restricted. A M8 bunged me a bootable CD with it on to try. Just type HDD Regenerator into google.
