Hi All,
I've had Zone alarm for a while and have recently updated to the latest version 7.xx , and it's started killing my machine.
Every time I start the machine a go into my user, it takes about 30 minutes before I can actually use the machine to load up an application. There's not a lot of apps auto starting, just msn live, skype and a few others.
Then to load any applications takes an age. Once into the apps they work fine.
Have checked the CPU load and the only thing running is the zone alarm process vsmon.exe and thats only taking up between 5% and 40%.
Anyone else experiencing this problem? any tips on solving it.
If I shut down zone alarm then the PC speeds back up.
Cheers
Taff
Cheers
Taff
