Hi All
I just installed Zone Alarm pro for the first time about 3 weeks ago.
Since then I have updated 2 times. The first was no problem but the second time I did it ZA started causing Windows shut down problems. The End Task box would pop up every time on a shut down.
After this I tried uninstalling ZA pro and reinstalling it with the new update only, but the same problem kept on accruing.
Has anyone else had this or know the best way to solve this ? Or is this just a Zone Alarm pro quirk that I'll have to put up with...
