** Zowie FK Pro 2300 Price Drop **
  • Thread starter Thread starter rjk
  • Start date Start date
how does the FK compare with Steelseries Sensei then?
Can't remember if it was the sensei or xai I tried now - can probably dig it out later to check but it was slightly smaller again than the FK and personally I didn't like the sensor much while broadly similiar to the WMO sensor feel wise it was far more twitchy.
Ah interesting :)
Might have to really try them on before I get one then :)
Turns out it was the Kinzu I was thinking about - Sensei is similiarish to the old MS Intellimouse 3.0 but I didn't get on with it myself - never got on with laser sensors personally (other than that a decent mouse IIRC).
Is this actually the pro model? or am I getting confused with the 2014 - these have 16 point wheels and yellow bottom and I thought the pros had 24 point wheel and black bottom?
EDIT: Seems a bit confusing as in some regions the "pro" is the same as the old one just renamed when they tweaked the sensor to remove angle snapping.
you think this is cheap but are asking for perixx?
the zowie is incredibly well built for the money.
As far as value for money goes some of the Perixx mice are unbeatable.
The MX2000II for example wins hands down against my old Razer Mamba. It is less than 1/5th of the price of the Mamba.
this isnt the new 2014 hence the price reduction.
Aware its not the 2014 model just a bit confused over the "pro" branding as the promo stuff from zowie the other day had "non-pro" as the yellow bottom, 16 point wheel and the pro as having a black bottom and 24 point wheel (black bottom version actually 2014 model?).
Unless the pre-2014 pro model is the same as the "non-pro" model and the 2014 pro is the one with the black bottom, etc.
