On the K-series the usual way the gaskets go is mixing the oil and coolant.
But they are also known to be prone to giving false symptoms - as in mayo in the oil when it's just condensation (as with most engines, but some are worse than others for it.)
Ultimate terminal signs are when severe water loss occurs, the oil actually emulsifies into choccy milkshake coloured goo, and the coolant looks like something you'd pull out of a McDonald's fryer, that is if you have any coolant left.
It is unusual for it to only occur one way - as in to get oily mayo but none in the coolant or vice versa. With the constantly changing pressures the exchange of fluids both ways is very common.
I wonder who remembers when engines were air cooled, and none of this was an issue
Mine is losing water at the minute, but that's the inlet manifold gasket, which I reckon a lot of garages think OMG must be the head gasket and charge somebody £500 for the work when 1 hours labour and £10 of parts will do the job. I have the parts and will probably do it next weekend.
The biggest symptom of HGF is mayo along with no hot air in the the cabin. Combustion gas leakage blocks the flow of coolant completely, with the IMG you get coolant circulation and a warm cabin, just regular loss of coolant which can be seen at the edge of the gasket.
