Is there a way to show fps ingame without fraps?
There's a fix to enable the -tickrate command line for servers now. 100 tick.
Personally, I have weird performance with this game now..
TF2 and L4D 1&2 play fine
q6600
gtx260
4gb
Not a beast of a machine, but it should play it fine at 1920x1080, and at the moment, it does not
Good news, is this through a server mod or have Valve done this?
Oh look, all that drama over nothing then.
Ive managed to pull of some headshots while my aim has been way off...
Well weird
Edit...
Netgraph 1 is poor compared to the old netgraph 3
Well weird
Edit...
Tbh I agree with prety much everything biohazard has been saying, but I can't be bothered getting into the argument.
Lots of people I know are annoyed at these changed and have never even played 1.6.
If the update doesn't effect you then brilliant, but for a lot of people it's horrible.
phew! good thing 100 tick fixes everything!
I love you.Go you.
I find it a bit annoying when it splashes up in my face.
Aye, completely agree with the vast majority of Biohazards points.
In my opinion, the 1.6-->CSS debate is irrelevant when referring to this update.
1.6-->CS:S was a new game, you had to buy it. CS:S-->CS:STF2 isn't a new game, it's an "update".
Try putting this in your autoexec might help your fps :
rate "35000"
cl_cmdrate "66"
cl_updaterate "66"
cl_interp "0"
cl_interp_ratio "1"
cl_lagcomp_errorcheck "0"
cl_lagcompensation "1"
cl_predictweapons "1"
cl_smooth "0"
cl_smoothtime "0.01"
Mat_queue_mode "2"
