Prison Architect
7 Mar 2005
Arkham
Went to Eurogamer today. If you want to buy into the Alpha you can get 10% off (making it $27) by using the discount code 'folsom'.
Hope that helps, makes it about 17 quid :)
10 Jun 2011
N.Ireland
Bought this over the weekend and had a quick go. It is surprisingly complex even at this early stage. It's more of a graphical Dwarf Fortress rather than a Theme whatever title.
18 Oct 2002
Manchester
Alpha 2 is out now! Improvements to the guards, including assigning sectors and patrols, a change in the intake rate system, and some mystery updates to food!
25 Mar 2004
Fareham
Bought this myself as well, that earlier discount code posted above still worked so thanks! :)
Looks like it should be a laugh to play. Perhaps a bit on the expensive side though, would normally expect a game like this to be a tenner or so at the most.
Caporegime
8 Sep 2006
On Ocuk
