I find it weird that I can get higher GPU scores 32K+ with CPU at stock. The higher I put the CPU, the lower the GPU score is.
Geeez, that is a bit bad that an update hides the fact that MVP is being used. I would have expected it to show it
Sorry to say guys but any new entry will need to have a GPU-Z validation link please. I will add this to the original post.
Yeah, it is strange indeed. Maybe we could do a scoreboard of MVP enabled systems for fun?
MVP = Multi GPU surely?
I haven't updated 3dmark11 yet (it has prompted me to). Does it do anything else besides get rid of MVP detection?
Validation link for MVP only or for everyone? As even validation can be hit and miss, I can validate my 7970 for just about any clocks I want as the clocks aren't tested. This could make things awkward
As for your scores dropping while OC'd are you running direct 100x50? I have a hunch you may need to open the bus a little bit maybe try 102.9 x 1.25 x 39 or 108 x 46* and see if it improves thing. 8 Pack did tell me Nvidia cards like a 108-110 bus while AMD cards like a 104-106 bus.
* Heavy bus clocking may require additional motherboard cooling.
Score
P9827 3DMarks
Graphics Score
11364
Physics Score
7303
Combined Score
6570
http://www.3dmark.com/3dm11/4780653
SCORE
P15644 3DMarks
GRAPHICS SCORE
19915
PHYSICS SCORE
10427
COMBINED SCORE
8421
Crossfire 7970's and i7 2600k at 4.6Ghz.
Can probably milk more out of it but thats running as i do normally.
I will make a note of the post number and will add it if we get a few entries
I hear ya but I feel we need a little trust and I have seen enough scores to question validity at times. I would have spotted Drs101's if I wasn't so busy doing my own tests.
It has worked well upto now and there is enough beady eyes to pull anyone I miss
I run my clocks at 125*40. This is very stable and seems to work well with the mem overclocked from 2133 to 2333. I have loose memory timings though and when I try to tighten them, it is a no show. To be honest, I am not trying for any higher. I wanted to pass 13K score on the P and have done that, so that is me spent now I will have a play with SLI at some stage just to see what returns I can get but not overly fussed.
As far as MVP goes, there is no real way of checking but I feel we will know if it being used and anybody submitting a score that is massively questionable will be caught out.
Have you tried 100*50 with the memory @2133 with tight memory settings. It should give you about the same for physics but might help with your graphics score.
I use the above when I do a 5.0ghz run but with the memory @2400 and have never had a problem with graphics score being lower. I normally get an increase of about 1500 going from 4.0ghz to 5.0ghz.
You may also find if you run the CPU @5.0 mem @2133 with tight timmings you physics score could even go up.
Edit I have just done a physics run CPU @5.0 mem @2133 score was just over 16800, if I run with the CPU @5.0 mem @2400 I score just over 17000 for physics.
