**Official Unigine Valley Leaderboard**
6 May 2012
Wigan
Whilst i appreciate your homo erotic offer i fear that this rape may turn into a murder should i accept.
Please take a moment to reflect and calm down. I know you don't like what I've said, but my only reply to that comes at the end of this gif my friend. ;)
:D:D:D
Caporegime
24 Sep 2008
Essex innit!
Temps are freezing outside tonight, so maybe a good time to do that bench/video and with the window open, you could potentialy get more.
I feel this is the only way Cyper. This will prove you didn't cheat but so far, it isn't looking good and I am neutral in this.
14 Oct 2003
South Derbyshire
Rape? Murder? Seriously? Any adults here?
What rules have I broken? Please enlighten me :o
The people of these forums pride them selves on running untweaked legitimate benchamrks to compete against each other, it's the gentleman's code you have broken.
Tweaking via third party or driver control panel creates a messy leader-board.
28 Jul 2005
Well I guess then KingPin would be called cheater here for using LN2 to freeze the **** out of the GTX Titan in his bench results.
Overclockers.co.uk indeed :D
I would let the OP to decide that, but knowing that you are all buddies here I wouldn't be surprised if he somehow get influenced on his decision.
I guess I would have to settle with the 5th spot on overclock.net and let you guys believe you hold the world record results in Valley* :p
*btw bench name is wrong in the title. It is Unigine Valley and not Heaven Vally.
3 Jun 2012
You wont proove it so why should be think its real?
How hard would it to record it on a phone with a quick glance at CCC settings and stuff?
It would shut us up and you get some praise.
Only a cheater would run away
14 Oct 2003
South Derbyshire
Give over, , I'm sure If I or Ltmatt cheated we could get 2500points, I might just do that and add it to OC.nets forum.
edit, I'm going to do just that.
3 Jun 2012
some people on there have MVP enabled, if i turn it on i will get 2500+ lol
Locky, When you get your cheat score let me see it :p
28 Jul 2005
I might do that but not today.
Lay the ground rules on what I should be recording exactly.
Are visual artefacts allowed?
3 Jun 2012
Are visual artifacts allowed?
Just a quick view of the CCC settings
And then the Run with its final score, you can even shout "AHA I WIN" at the end :p
I get some minor artifacts on mine, but i cant say what others would think about them.
Caporegime
12 Jul 2007
United Kingdom
Just a warning its possible to set up short cuts in CCC to apply tweaks with the press of keyboard buttons.
Caporegime
24 Sep 2008
Essex innit!
With those clocks Cyper, I would expect that visual artifacts are common. For sure artifacts are allowed but setings must be default (not sure what that is in CCC).
This would prove you obtained the score legit and apologies would be needed and made. :)
Record your settings and then go straight to the bench and then let it finish showing the score. :)
