However this time I do need to back out on pyramid building, were just too busy.
Come on now, don't make us drive up there to build one for you....
Gibbo might be running the card in silent mode and so it gets very hot, in uber mode it's not as silent but runs a lot cooler.
Hi m8
What do you mean by this, we can't find anything in regards to a silent mode / uber mode, do you know more about this?
Hi m8
From Legitreviews, who posted the 4K display performance charts of the Radeon R9 290X we came to know that the card operates under two modes. One is the Quiet mode at which the cards were tested at while the other is called Uber Mode which the Chinese site didn’t provide any detailed information but shows that it gives a slight bit of a performance bump over Quiet mode so its probably some new Power and Performance management algorithm which would only be detailed once the reviews go live.
Hi m8
I should add that the HIS 290X i posted earlier had Hynix. MSI have always used Hynix as well.
MSI is the card to get then with their excellent RMA service.
God I hope the 290 pros aren't all Elpida, the Sapphire is...
Yea...might have to up budget for the 290x instead of 290 if that is the caseGod I hope the 290 pros aren't all Elpida, the Sapphire is...
