** AMD R290X NOW AVAILABLE & OVERCLOCKING REVIEW!! **
7 Jan 2010
Up NORTH
Hi OC any Idea when there will be anymore stock of the BF4 edition as you have the best prices and Im not paying £515 for the same card from another etailer
22 Nov 2007
Ayr, Scotland
I'll tell you what a 290X at 1200 core matches my stock 7950 crossfire setup. :cool:
Gibbo's 290X @1200/1500 - Valley - 73.1 FPS - Score 3059
LtMatt's 7950 Crossfire @925/1250 - Valley - 73.1 FPS - Score 3059
That is impressive. :)
Yep just gonna say the Heaven 4.0 benchmark for the OC 290X is almost identical to my stock 7950 crossfire, impressed, especially with the price but my 7950 crossfire will be way cooler and lots of room for overclocking. :D
25 Jun 2013
Warks
It's just ahead of my 670 SLI with both cards at max overclock. I can get about 70-71fps.
edit: actually, ignore that - it's Heaven not Valley. The 670s are just ahead instead.
Caporegime
12 Jul 2007
United Kingdom
Yes same here, still the 290X can go further i bet. I'll be happy to run a comparison at an overclock vs a 290X user (maybe Kaap) that will push the cards further than 1200 core 15000 memory.
Interesting, thanks for the info teppic. :)
25 Jun 2013
Warks
I made a mistake ;) My Heaven benchmark is about 70-71fps with max OC, while the 290X is 65fps in the benchmark here. That's still really impressive for the 290X though given these are high end 670s with excellent cooling.
Caporegime
12 Jul 2007
United Kingdom
Furry muff. I was comparing Valley Extreme HD preset on 290X vs 7950 Stock. :)
7 Jan 2010
Up NORTH
its getting silly NOW :) nearly 8k form a competitor
XFX AMD Radeon R9 290X 4GB Graphics Card
Includes Battlefield 4
4GB Graphics Memory
Interface Type - PCI Express
Cooler Type - Active Fan
Outputs - HDMI, DVI and Display Port
Code: VGA1922
Mnfr Code:
CGAX-R929XBF4
10+ more expected on 12/11/2013
Free Delivery
£7,920.66 inc VAT
7 Aug 2012
would a 120mm radiator be enough to cool one of these in its own loop?
Yes, it would be capable, but given the heat this card seems to put out, if I was WC it, I would be doing so to get best out of it so would want as much rad space as possible. Dont think I would go to expense of WC it without 2x120 rad space at least, in its own loop. In a loop with CPU would be 3x120 minimum, but most likely 4x120.
Also depends on the thickness and efficiency of rads, plus tr kind of fans and acoustics you are willing to bare!
22 Nov 2003
Cardiff
When are your pre-fitted waterblock ones coming into stock Gibbo, and what memory will they have?
£30 seems quite a reasonable premium to pay so I don't have to fiddle about fitting one myself :)
