**THE NVIDIA DRIVERS THREAD**
Caporegime
8 Sep 2006
On Ocuk
I've had a number of driver has stopped responding issues in some games, numerous reports on nvidia forums. I'm going to test the modified Quadro version right now:)
15 Feb 2006
Staffordshire
OK so far for me on 480 SLi. Few issues on COD Ghosts with the last WHQL (Had to use NVidia nspector to force SFR SLi rendering to keep weapon scopes from flickering) will try ghosts on these later.
Caporegime
24 Sep 2008
Essex innit!
Can any one confirm if BF4 is still broken? Just had a bf4.exe stopped working error and not played it in weeks. On the latest drivers with a complete DDU uninstall/install.
I should check other games but not in the mood.
9 Nov 2009
Is there some kind of X-Fire issue in BF4 (DX11)?
The GPU taking much longer to satisfy each frame than the CPU, as shown in the bottom left hand corner.
It appears as if each frame is still waiting for the GPU despite being x-fired with a result of 78fps? What does the graph reveal here?
Caporegime
24 Sep 2008
Essex innit!
Well I was having some serious issues since going SLI and BSOD every 5-10 minutes and no matter what I did, it would still do it. After metest86+ coming back clean and it still pointing to the nvidia drivers being the cause, I was ready to smash up my computer. I thought I would give it one last shot with Display Driver Uninstaller and problem solved. What a gem of a program. I am running latest beta's and touch wood, no issues. Just looped heaven for an hour and no probs at all.
Tl: DR - If you have issues, give DDU a run. fantastic program :)
Caporegime
14 Dec 2005
armoy, n. ireland
Tbh, your graph looks pretty ok in that ss. Only wish mine was like that.
Caporegime
12 Jul 2007
United Kingdom
Lol. That is because each gpu is rendering a frame so you get double the rendering time hence the line above the cpu. Also that is on DirectX 11. Now take a look at the green rendering line under Mantle.
28 Feb 2013
Birmingham
The latest drivers are working great for me with 2x SLI 780s, no issues at all really. I'd say that the past 4-5 months of Nvidia drivers have been good overall, some nice performance boosts - compared to the whole 320.18 driver episode (I, personally, had no problems with 320.18 but many did of course).
28 May 2007
Probably best to put this in the amd drivers thread as this is the nvidia driver thread.
