White Out
17 Mar 2009
UK
Great job and to me that's up there with the best :) I was wanting to sleeve my pump too and have never done tried it though I'd love too, which sleeving did you buy?
OP
6 Aug 2010
Suffolk
Thanks for the comments guys!
I use MDPC sleeving, I tried others but Nils has the best! Also tried other atx removal tools, the one you get from MDPC is the best, makes it so easy anyone can do it!
If you need any advice on sleeving just YouTube Lutro0!
OP
6 Aug 2010
Suffolk
Another update, all PSU cables are now sleeved!
*^* 24 Pin cable done!
*^* Monsoon Temperature sensor, before i decided the standard sleeving wasn't good enough....
*^* After I'd finished sleeving, a much cleaner look!
18 Oct 2002
Hereford
Roady, 46 posts to enable MM :)
Where did you get your sleeving from Roady?
I've ordered some more, silly i didn't order enough last time round! will post pictures of all of it once i'm finished!
Nils of course! I did the same and didn't order enough the first time around!
Still fairly short of the smaller heatshrink! Argh! If you're ordering more MorleySA could you grab me some? If you've not placed your second order yet...?
Shame Bart, Email me (Trust) if you're interested and we can sort something out! ;)
OP
6 Aug 2010
Suffolk
I've already placed and received my order mate sorry :(
On another note...I've ordered these fans for my build today.....
*^* I've ordered the B12-3 that spin upto 1900rpm @26.5dB
Also pre ordered the White Enthoo Primo!
12 Feb 2013
East Mids
Really tidy job on the sleeving, that 24pin cable looks great. Even managed to get all the heat-shrink lining up perfectly.
Can't wait to see those fans in the white enthoo!
18 Oct 2002
Hereford
Wow they look awesome, I looked for these but they don't do them in 140mm! :(
Using Enermax Everests, bitfenix spectres and some NZXT currently...
18 Oct 2002
Hereford
So jealous of how good they look! ;)
Can't wait until you get those rads mounted now... Thought about painting the fans? Glossy white blades on matt white (more off-white?) rads?
Really need to update my build log as got my Hale fitted, along with lots of sleeved cables and graphics card changes! :D ;)
