**Official THIEF-Incorporating AMD™ Mantle™/True Audio™/Bench mark Thread**
Status
Not open for further replies.
Caporegime
24 Sep 2008
Essex innit!
Pretty sure it was FPS locked for me then too.
An in game shot with full details for me.
31 May 2012
Make sure you have Vsync turned off if you are being capped at 60fps, I had the same issue till I realised it was enabled.
25 Nov 2011
The KOP
Wow! TrueAudio is stunning :D the difference it makes to the surrounding environment. Only onto the second level and so far really liking it. Started on Master setting.
What I have noticed is the game don't seem to be using second card? Hwinfo reports no usage.
Caporegime
18 Sep 2009
Dormanstown.
I also see gains across the board with Mantle over Direct X (Again, I still think the benchmark is largely irrelevant to gameplay)
This is my R9 290 - 50mv @ 1050MHZ/1200MHZ (Pretty quiet)
I've taken pictures on my phone so you can/can't see the OSD and also I screenshots don't always work :p
Here's the DirectX 11. Could have swore I got higher mins before I updated the driver......................... *Tin foil hat*) ;
Here's Mantle
Higher FPS across the board (Derp)
What about 3D martini?
It's greyed out for me.
Greyed out, I also can't see a none TA option.
Status
