**The New Official THIEF-Incorporating Bench mark Thread**
Man of Honour
21 May 2012
Dalek flagship
Nice scores Kaap. Why DX11 only?
I came within an ace of blowing up my 4930k trying to run Mantle at 4K and that was only @4.0ghz.
The VRAM memory problem with Mantle causes massive instability and thrashes the living daylights out of CPUs, fortunately it is not so bad on BF4.
I did do a couple of Mantle runs in between loads of crashes and will post them later. The two card run was worse than DX11 and the three card run was a bit better. I decided to give up when my CPU and PC powered off with the 4930k @4.0ghz and using 1.4v, even this was not enough to keep things stable.:eek:
Caporegime
24 Sep 2008
Essex innit!
Wow!!
Caporegime
OP
17 Mar 2012
ARC-L1, Stanton System
Probably because with Mantle its pushing all the CPU threads instead of just a few like in DX.
Man of Honour
21 May 2012
Dalek flagship
Just run these to show memory usage @4K on 4 cards with DX11 and Mantle.
DX11
Total used 16gb, pretty close but ok.
Mantle
Total used 18gb, not so good and I think the problem is the dynamic memory being swapped out.
