- 26 Aug 2004
Your lower Than my 780 but I had a 1215 MHz overclock but I am sure with some tweaks you will be way ahead of mine.
Heaven and Valley love Windows 7 and older drivers.
i7 920@ 2.66ghz
GTX 580 @ 800\2004
[Am I right that higher cpu clocks make little difference in this benchmark?
With fast cards the CPU clockspeed makes a huge difference.
If you run 3 or more cards it is pointless to run this bench at 1080p due to the CPU bottleneck. For best results 1600p or higher is needed.
Done
cant see it?
I'm in the ultra list?
Can't be right?
#1840 - 280X @ 1030/1500 - dtsrules
#1831 - 580 @ 800\2004 - easyrider
9 points less than a 280x with a GTX 580?
Your right, i just noticed your running 4x AA with it, shouldv' kept quiet
