**Official Unigine Valley Leaderboard**
4 Jan 2009
Derby
I would set power limit to max and over-clock the core to 1189 and the memory to 7400 ish, then you should find it performs a bit better.
I now get 3211 on windows 8.1, but that is with everything running in the background, Cant be bothered disabling anything in windows 8.1, I found valley likes high memory clocks.
2 Nov 2012
Sussex
Heaven and Valley love Windows 7 and older drivers.
Had numerous attempts trying to beat my old score, think I tested with most of the drivers since the launch ones for the 780's. Smashed it with the latest ones and while I did have little help from volt control and higher clocks on the GPU's they weren't that much higher to account for the big improvement I made. Long story short, latest drivers are golden in my opinion.
Caporegime
24 Dec 2005
Autonomy
i7 920@ 2.66ghz
GTX 580 @ 800\2004
Am I right that higher cpu clocks make little difference in this benchmark?
Caporegime
24 Dec 2005
Autonomy
Your right, i just noticed your running 4x AA with it, shouldv' kept quiet :D
what list am I actually on? :confused:
Shouldn't I be on this one?
Leaderboard: High 1080P
1, #3388 - 290P @ 1100 / 1250 - Sacrifice
2, #3126 - 680 @ 1320 / 1800 - khemist
3, #2431 - 280X @ 1030/1500 - dtsrules
4, #2199 - 7870 XT @ 1150 / 1600 - Jony27
5, #1909 - 660 @ 1133 / 1625 - Defconluke
6, #1846 - 660 @ 1329 / 6008 - SeraphX
7, #1582 - 480 @ 900 / 1900 - SeraphX
8, #1575 - 480 @ 820 / 1900 - arc@css
9, #1338 - 5870 @ 850 / 1250 - billysielu
