Sniper Elite V3 Benchmark
30 Nov 2011
I wasnt talking about that guy... When I played through it it was just much easier to play it like any old fps than it was to even try being "snipery", the game just seems to constantly punish you for even trying, so load up on automatics and ammo and just blow everything away as they blindly run towards you through a choke point :D
Man of Honour
OP
21 May 2012
Dalek flagship
4 GTX 980 @1482/1982
5960X @4.5
344.80 drivers
1080p
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-11-23 at 15:12:01
Version 1.15 Build Version: 2014.11.12.001
Average FPS: 250.1
Minimum FPS: 23.0
Maximum FPS: 1160.0
Number Of Frames: 18963
Average Frame: 3.998ms
Minimum Frame: 0.862ms
Maximum Frame: 43.542ms
Machine Name: HAL
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16265MB
CPU: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
Number of Cores: 16
GPU Name: NVIDIA GeForce GTX 980
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
4 GTX 980 @1492/2000
5960X @4.0
344.75 drivers
2160p
Created: 2014-12-01 at 19:40:36
Average FPS: 57.5
Minimum FPS: 6.3
Maximum FPS: 711.2
Number Of Frames: 4391
Average Frame: 17.382ms
Minimum Frame: 1.406ms
Maximum Frame: 158.169ms
Machine Name: HAL
Monitors: 1
System RAM: 12169MB
Number of Cores: 16
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
GTX 980 @1502/2000
5960X @4.0
344.75 drivers
2160p
Created: 2014-12-01 at 20:00:09
Average FPS: 18.5
Minimum FPS: 5.2
Maximum FPS: 272.4
Number Of Frames: 1430
Average Frame: 54.164ms
Minimum Frame: 3.672ms
Maximum Frame: 193.864ms
Machine Name: HAL
Monitors: 1
System RAM: 12169MB
Number of Cores: 16
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
12 Jul 2007
United Kingdom
Results are in. That 4K score is badass! :cool:
[email protected]
4x290X@1225/1625
14.1.2
1x1 Optimize
4K
Created: 2014-12-01 at 13:51:29
Average FPS: 78.1
Minimum FPS: 7.3
Maximum FPS: 1092.0
Number Of Frames: 5904
Average Frame: 12.807ms
Minimum Frame: 0.916ms
Maximum Frame: 136.926ms
Machine Name: MATT
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16253MB
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
1080P
Created: 2014-12-02 at 08:22:30
Average FPS: 241.2
Minimum FPS: 25.2
Maximum FPS: 1055.4
Number Of Frames: 18226
Average Frame: 4.147ms
Minimum Frame: 0.947ms
Maximum Frame: 39.654ms
Machine Name: MATT
Monitors: 1
System RAM: 16253MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
12 Jul 2007
United Kingdom
[email protected]
4x290X@1225/1625Mhz
14.12
1440P
Created: 2015-01-24 at 11:58:58
Version 1.15a Build Version: 2014.12.09.001
Average FPS: 158.8
Minimum FPS: 13.7
Maximum FPS: 1131.6
Number Of Frames: 12008
Average Frame: 6.295ms
Minimum Frame: 0.884ms
Maximum Frame: 73.094ms
Machine Name: LTMATT
Monitors: 1
System RAM: 16253MB
Number of Cores: 8
Resolution Width: 2560
Resolution Height: 1440
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
