The AMD Driver Thread
Suspended
30 Mar 2010
Under The Stairs!
Hi all,
Just looking for a little help regarding a first AMD install please :)
I would remove everything Nvidia via NCP(don't reboot)>Power down swap gpu's>Power up and wait for MS legacy drivers to install>Reboot and Install Omega driver>Reboot.
Boot into safe mode, run driver sweeper and then, remove old card, put new one in and install the latest Drivers, 14.12 atm
Then you run the risk of:
DS/DDu are great tools but can cause problems.:)
18 Mar 2012
Eastbourne
Ah right, i didn't have this problem when i done my brothers. Fair enough, well it's up to you :)
Suspended
30 Mar 2010
Under The Stairs!
I think it might be time for a 'How Well Does Crossfire Scale' thread covering performance from one gpu, to two gpu's to four gpus. Sounds like a fun little project!
Get It Done Lt!:D
I've also seen the new drivers in action with an improved Dying Light Crossfire profile and it was working well on QuadFire too at 4k. :)
Oh you dirty tease you! :p
Suspended
30 Mar 2010
Under The Stairs!
Used DDu to remove everything Nvidia and when I took it out my 670 from my 290X rig, and reinstalled my 290x mgpu, and Ethan Carter throws up that nvtt64.dll, it might not happen to all but ymmv.:)
Looking like an OS instal to fix, but im too lazy for that.:D
Don't get me wrong, using DDu on Amd driver updates works fantastic 99/100, for the unfortunate 1, then it's corrupt OS time.:(
22 Oct 2012
The Moon
Hi Matt :)
Sometimes when I load MSI Afterburner, the PC just freezes, do you reckon there's a setting to fix something in there? E.G force constant voltage? or disable something?
Man of Honour
20 Sep 2006
I'm not quite at the rioting stage yet, but it's a sad state of affairs for AMD to have no proper crossfire support for the newest games. Waiting months upon end and being given no time scale for a fix is getting increasingly infuriating.
I've spent near to £200 on games in the past few months that run poorly. I understand it's not always just down to AMD (as in the case of Ubistutter games). I'm just really wondering why I should stay with AMD on my next upgrade. I'd love my next buy to be a pair of 390Xs but I have the feeling I'd get shafted trying to play new games.
Crossfire has enough problems as it is, but if this is the way it's going to be I might have to switch to the dark side.
After having lots of problems with my 290X's in several games, and no fixes in sight after months and months of waiting, I finally bit the bullet and bought a 980. I don't mean to bash AMD, but I have no regrets. I wish I'd have done it sooner.
Caporegime
OP
12 Jul 2007
United Kingdom
Hi Matt :)
Sounds like some hardware might not be stable on your computer, as afterburner should not normally cause a lockup. Are you running everything (including your cpu and memory) at stock clocks?
14 Dec 2013
That would be good!
I'm weighing up getting a 295x2 or another 290p and would love to see the difference (if there is one)!
You wont regret getting a 295x2, at the price they are now they are astonishing value. It just oozes quality IMO.
I paid £440 each for my MSI gaming 290x's last year and picked up a Gigabyte 295x2 a couple of months ago for £500! :eek:
22 Oct 2012
The Moon
Just tried Thief, benchmark says around 60, in game I get this lol...
B99uEy2CQAAQCDj.jpg:large
18 Mar 2012
Eastbourne
Them 295x2's are gorgeous cards, I'd love to have a pair in crossfire.
I know it would be totally pointless and I know amd have a big crossover so could you ctoss fire a 7850 with a 290x as I've seen people say stuff like that when I've searched something about crossfire and yahoo answers or something has come up.
Just out of curiosity :)
14 Dec 2013
As far as I know you need to crossfire similar GPU'S, so the Hawaii family will work together, Tahiti will work together, but Hawaii and Tahiti will not.
