The GTX Titan X owners thread.
25 Mar 2013
Redditch
guys
How easy is it to watercool a Titan GPU? and what would I need, my CPU is cooled with the following
Pump:EK -DDK PWM 3.2 X-Res
240 rad
EK - Supremacy Nickel water block
You prolly seen the photo of how its set up in the photo I posted earlier in the thread
Im thinking water as one card on its own seems to be ok for me rather than SLI like the 980s
it would scare me removing the STOCK cooler :)
19 Jul 2011
Reading
guys
240 rad
Its easy as pie, stock cooler is screwed on from the rear of the card and comes off in one whole piece , clean the die , fit the block and your away , just plumb it into your existing loop, idealy however you'd need another 240 rad, but you can see how it goes.
I prefer more rads and silent fans.
26 Aug 2005
Hi all,
Card arrived yesterday but I ended up having to stay late at the office. Stupid year end! :mad:
Impressions so far:
1. Seriously quick, a huge jump over the 780 Ti
2. No noisier than the 780 Ti (mine has the Titan cooler)
3. A lot less coil whine, although it is still there when going through menus on some games. Not worth complaining about though!
Up to a stable 1300 boost and 8000 memory so far after benchmarking in 3dmark, heaven and playing ACU for half an hour or so. I've got the weekend to see if I can push it further though as it doesn't even seem to be breaking a sweat!
Unfortunately I don't have a lovely looking parrot to pose for me, just a cheeky hamster and the chances of her staying still for more than 2 seconds are zero!
