Newbie OcUK member! Figured I should join, since this thread on the Synology / Microserver combination is one of the more active ones around. Updating the BIOS and setting up Xpenology was all pretty painless.
I've recently shifted from WHS2011/DriveBender on a N54L to Xpenology on another N54L, moved everything across, etc; 4x 3TB Hitachi and Toshiba drives in SHR with a single parity drive. The performance is similar overall, however Xpenology manages with a lot less RAM (I've got 4GB ECC in there, down from 8GB ECC), lower CPU usage, and seemingly overall faster response / raw IOps - all while still handling SABnzbd, Couchpotato and SickBeard. It's also a fair bit easier to manage.
I've also re-used an old N36L to set up a second unit, currently just with 2x 2TB drives; this is supposed to be a versioned backup of the important stuff (documents and photos), possibly with cloud backup as well - Glacier looks tempting. I'll need to add more drive in due course. I'm still debating whether to add another 2x 2TB to easily make a SHR array, or get four new drives.
Issues so far:
- sometime yesterday, the N54L Xpenology just died; rebooting wouldn't bring it back up, somewhere between swapping 8GB ECC for 4GB ECC and resetting the CMOS I made it work again. All fine now, strangely, but will keep an eye on it
- I booted one of these up at 100Mbps NIC speed (4-wire cable, by mistake); despite swapping the cable to a 8-wire while running and the Status showing 1000Mbps, transfers were limited to 100Mbps until I rebooted; maybe just a bug.
Happy to help with any questions etc.
