The Fury(X) Fiji Owners Thread
5 Sep 2011
Surrey
It's quiet enough, some people would find my TITAN X Tri SLI build intrusive with the 1080mm rad. I guess it's personal pref, as I find the rush of air non intrusive as it's deep and dull. Where as this pump however mild is ear piercing lol.
Honestly though, when the acrylic roof is on this Lian Li it's barely heard
Edit: hard to tell on microphone but mine doesn't sound anywhere near that bad.
Caporegime
18 Oct 2002
Ireland
Wonder if lowering the voltage would do anything, has an odd connector on it though. PLus how much do you lower it before the pump just lets the gpu cook?
And still nothing from ocuk or the amd reps on this :( Even through twitter roy taylor is saying FA. Apparently burying their heads in the sand is the best thing to do at this point.
5 Sep 2011
Surrey
Issues. He got the arse ache over people claiming the polling tweak on NV was working as it was interrupting whatever timing issue that was present. Looks like he's back to being a delight.
10 Jul 2009
London
https://flic.kr/p/vpyVQJ
https://flic.kr/p/vqrKZ8
https://flic.kr/p/vnN32G
folding@home 426k ppd cards are laughing load temps of 53C with room temp at 28C. And fans are absolutely silent spinning at 951RPM
Oh, and I received something which hopefully does not belong to any of the cards:
https://flic.kr/p/v8DHMD
it fell out of the radiator fan. I don't see anything resembling this piece on other card. And they both are chugging along nicely.
To be honest fans make a racketing whine when at max revs. But as they spin only 951RPM max at load, so they are completely silent ;)
Caporegime
18 Oct 2002
Ireland
Looks like a piece of liquid tubing :eek:
5 Sep 2011
Surrey
My personal opinions are my own and I don't want to fuel a fire, but being frank I think AIO solutions are just diabolical anyway. Even the fitment on the Corsair units is cheap crap. Custom blocks are half as much effort. It's just hard to picture them as a viable off the shelf solution what with fitment of the radiator if you already have items in your case using mounting points.
I know Matt installed 4 in his but the system has sod all else in it, and is running the CPU of yet another off the shelf unit. Fitting units like this one you just tie your customers in to these problems.
10 Jul 2009
London
Thinking same :p
Least they not making a racket :D
there is no leak, so that piece is not mine. I guess down in factory there might have been an accident and unit was smashed or something, and that piece just got into my box.
And yes, fans, pump are completely silent. there is usual pump humm coming out of the cards, but you basically would need to put your ear inches away from the cards to actually hear it.
P.S. one of the cards has push pull system now, due to the front corsair case fan, which I spun around to push air same direction as fury fan :D
temps are absolutely fantastic :D
Caporegime
8 Jul 2003
In a house
:D
