Caporegime
- 18 Oct 2002
What was your previous cpu?
I would say keep both fans. I experimented with others but found temps are best with the ones provided.The H55 is all you need. Quiet and keeps temps below 55 degrees.
Anything pricier is pretty much a waste.
Just have to factor in another 14£ or so for a better fan.
(the only bad thing about the G10 is that it looks hideous).
8350.
I wasn't able to get the card utilised consistently in terms of vram usage which I believe indicates bottlenecking?
I was also getting some little slowdowns in games which only happened after I got the card but before upgrading.
Everything is running well now though.
The key to low case temps seems to be a high CFM fan on the H55 prevents the GPU backplate getting even warm as it chills the radiator keeping fluid temps low. Soon as I either lowered the fan RPM or used another lower CFM model case temps went up rapidly.
Changed back to the Corsair fan @ 1700RPM case temps went right down so did the GPU temps (from high 50s back down to mid 40s just using the supplied fan).
My fan supplied by Corsair must be different its fairly quiet @ 1600rpm from 1ft away! From about 5ft away its almost 100% silent you can only hear the case airflow.If you used a bad fan is a different story
The right eLoop, Vardar, Noctua and others will give you the same performance for less noise.
I can hear the stock one on anything above 40% (750rpm).
Please let us know how that one is but I cannot see it being silent if it pushes that much air out! You will hear the airflow even if the actual fan mechanics are silent the blades cause the noise. Then some areas of your case will amplify this.I'll see how good this one is once it gets here next week, should be just as good.
As far as PWM goes you can still select a custom curve (or a static percentage)!
Avoid PWM as well if you want silence they are not silent once the motherboard bios profile ramps up PWM volts to match internal temps.
could be latest drivers, I had to take mine back to 355.98 because the new one runs terrible. I was getting low utilisation with both cards and even worse performance than with a single card. I also had a similar instance where one got stuck at something like 800mhz and after a restart it came back up.Had a weird one today.
I was messing with my monitors to set my side and top ones to 2160p via DSR and when I went to play GTA I was getting 40fps...
Checked in MSI and core clock and memory clock were only topping 450mhz each!!!
Restarted my PC - all back to normal at 1400mhz and 3900mhz.
Very strange.
