Yeah I spotted your other tread.
£150 now! Ouch. Will wait and grab them when there closer to £125.
Anyone done a back to back with the X2's?
I'm half-contemplating the upgrade..
Italy you are not going to hit by custom charge/import VAT (plus RoyalMail/ParcelForce ransom) I think?dry headphones?! I would never describe X1's as dry but there you go
Nearly ordered X2's but I'm a bit drunk, deciding between ordering from Italy and the US...
Just changed the cable from Fisual S-Flex Mini to KabelDirekt Pro
After reading about I noticed loads people saying KabelDirekt was a better cable at £6 I though worth a gamble.
Can honestly say am abit shocked tbh they is a noticeable difference, base is much tighter and mids sound more detailed.
i think the biggest change is defo the base, it sounds so much better and cleaner if that makes sense.
You told me? I must have missed the post.
Didn't mean told you personally I did post about the kable direct cable opening up the fidelios a bit though
I told you ! pats trusty kable direct cable my fidelio x1 are going nowwhere so much better for gaming than the hd 650's which sound thin for gaming.
X1's don't have replaceable pads. I think that's one of the changes that Philips brought with the X2, among others.
