**THE OFFICIAL AMD CHIPSET DRIVERS THREAD**
14 Nov 2002
Thats good enough for me, I tend not install drivers if windows hasn't any unknowns in device manager. Unless there is a specific need, if it aint broke .... :)
I do install gpu drivers, but tend not to update them if all is well.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
I used to update more often in the past, these days I also think if it ain't broke don't fix it. Unless there is a new game coming out and there are drivers that help with it. When I do a clean install of windows (whenever I change GPU usually) I always go grab latest stuff though.
30 Jun 2006
Horsham
Driver Name
Previous Version
New Version
Change Details
AMD Ryzen Power Plan /
AMD Processor Power Management Support
6.0.0.7
6.0.0.9
  • Updated Ryzen™ 7 desktop setting to support power slider and quiescent mode
  • Updated Ryzen™ 7 mobile slider setting for Better Battery and Better Performance
AMD PCI Device Driver
1.0.0.81
1.0.0.82 Bug fixes
AMD I2C Driver
1.2.0.111
1.2.0.117
  • Fixed the Synchronization when there is a delay
  • Robust Error Handling in case of ghost interrupt
AMD UART Driver
1.2.0.112
No Change
AMD GPIO2 Driver
2.2.0.130
No Change
PT GPIO Driver
2.0.1.0
No Change
AMD PSP Driver
4.13.0.0
No Change
AMD IOV Driver
1.2.0.49
1.2.0.52 New device ID support added
AMD SMBUS Driver
5.12.0.38
No Change
AMD AS4 ACPI Driver
1.2.0.46
No Change
AMD SFH I2C Driver
1.0.0.86
No Change
AMD USB Filter Driver
2.1.11.304
No Change
AMD SFH Driver
1.0.0.312
1.0.0.313 Human Object Detection (HOD) feature added
AMD CIR Driver
3.2.4.135
No Change
AMD MicroPEP Driver
1.0.28.0
No Change
Not a huge update by any means but always welcome.
11 Dec 2016
Oxford
that slider did nothing for my 5800X, I thought it was common to all Zen 3... Turns out only lucky 8core owners
Will test and see.
How is it supposed to behave anyway? I remember reading that with Zen 3 CPU itself is deciding about boost and idle, much faster that OS could.
Edit: Updated chipset drivers, slider still doesn't do anything
21 Jul 2005
Officially least sunny location -Ronskistats
Same, since chipset and GPU drivers are quite important, if the release does not state its fixed a) something I was experiencing or b) an improvement I would like to see I now leave alone (I like stability).
Caporegime
8 Jul 2003
In a house
Im the same, if it aint broke..............
Read some reports of these also not being able to be installed like the last set, and then they aren't able to get their previous set back on, or any at all. :p
Ree
Ree
22 Aug 2016
mine looks normal currently 31 and my tower sits right next to a radiator which is on. gpu is only 1 degree warmer idling too.
