Caporegime
Does windows always install latest chipset drivers? Doubt it from my experience. Bit like Windows installing gpu drivers, it does, but not latest.Doesn't windows update install necessary chipset drivers as it does with intel ?
I used to update more often in the past, these days I also think if it ain't broke don't fix it. Unless there is a new game coming out and there are drivers that help with it. When I do a clean install of windows (whenever I change GPU usually) I always go grab latest stuff though.Thats good enough for me, I tend not install drivers if windows hasn't any unknowns in device manager. Unless there is a specific need, if it aint broke ....
I do install gpu drivers, but tend not to update them if all is well.
New chipset drivers yo!
Revision Number
2.13.27.501
File Size
51 MB
Release Date
2/4/2021
Revision Number
2.13.27.501
File Size
51 MB
Release Date
2/4/2021
that slider did nothing for my 5800X, I thought it was common to all Zen 3... Turns out only lucky 8core ownersRyzen™ 7 desktop setting to support power slider and quiescent mode
Same, since chipset and GPU drivers are quite important, if the release does not state its fixed a) something I was experiencing or b) an improvement I would like to see I now leave alone (I like stability).
Revision Number
2.13.27.501
File Size
51 MB
Release Date
2/4/2021
Revision Number
2.13.27.501
File Size
51 MB
Release Date
2/4/2021
CPU seems warmer when idling, anyone else?
