Neovim or Vim?
1 Nov 2007
England
I need to learn to use Vim because it'll be much easier to work on remote files using SSH than using Nano, which I use now. I've been doing some searching, and Neovim looks good. I also like that you make plugins using Lua, a language I find easier than VimScript. I also hear that Neovim pushes changes faster than Vim.
Which would you use and why?
5 Mar 2010
I use vim quite a lot (or vi if vim isn't installed) not ventured elsewhere but typically the software I use already has vim installed, so would be a bit of a faff having to install another package.
15 Sep 2009
Manchester
I tend to use vi/vim just because of the nature of the systems I ssh on to - we don't want to be installing additional packages into them to maintain/have issues with. Vi or Vim come default.
OP
1 Nov 2007
England
Thank you both. What I wanted to use Neovim for was as an IDE and something I do quick edits with when SSH into a machine. From what I can gather, even if I used Neovim on my Mac, it'll be similar enough to Vim on Linux / BSD so as not to cause too many problems.
I think they need different config files, so I'll have to put two configs on a new server rather than one.
8 Oct 2020
If you just need to learn the vim commands then there are plugins for Vscode, etc. Neovim is cool but it can be a lot of setup, whereas some like Vscode is a quick install and then download your plugins.
OP
1 Nov 2007
England
I think I'll give Neovim a try and see how I get on. At worst, it is a bit of wasted time.
15 Sep 2009
Manchester
You can use Neovim as an IDE if you want yeah, it's pretty popular - my development needs I guess don't necessarily need a fully fledged IDE, I write mostly bash, terraform, ansible, powershell and a smattering a python - but I use vim for lots of reading/searching/querying log files, services etc.
OP
1 Nov 2007
England
I have a couple of projects with hundreds of source code files, and I'm hoping Vim or Neovim make it easy to browse large projects.
