Ryanair buys 75 737 Max
15 Mar 2010
Bucks
Oh my God. That is shocking. I honestly think it's one of the safest forms of transport, until pilot experience, training & ability under pressure is put to the test. At that point you really are *****.
Having seen those Air Crash Investigation programs as well, it doesn't matter how insignificant the issue is, it escalates very quickly when the plane doesn't respond in the way they expect.
Love the quote from that article “Engine fires are a very unlikely event and there have been no observed engine fires in the 787 fleet history."......but if there is one the chances of survival are put at risk by a sticky switch. According to them, 1% chance the button won't work. If I was in are air on a Dreamliner looking at a wing on fire knowing what I know now...
Ultimately its a training issue. Most flight issues can be solved with good training, but airlines are ever trying to bottom it out since its impacts budget. Generally speaking the pilots ferrying around cargo globally are better trained and experienced than the ones that are flying people around (think about that!)
Although in the both Max crashes they've pretty much proved now that even with training it would have been near impossible for it to be saved, and in fact the systems were just flawed from the very beginning.
19 Feb 2010
London
What if one fails and the 2 remaining disagree? Which one is correct? 4 sources for anything critical please.
Example with network time protocol:
The thing with that particular example is it's still usually possible to figure out if something is catastrophically wrong - upon failure of an NTP server for example (which was assumed to be correct), systems can fall back to to internal clock which isn't great but will stay reasonably accurate for a short time until they can sync to another source. If you have other sources available that are way off your current time then it can refuse sync, raise alarms/alerts and continue on internal.
I've hit exactly this sort of issue before with PTP and NTP (unfortunate coincidence with multiple problems at the same time). But yeah, more than 4 sources in our environment. :)
19 Jun 2009
Central Scotland
Why? This is a "normal" occurrence in aviation; it's only being reported because it's a MAX.
This was my initial thought tbh.
Then I remembered that the MAX's engine mounts were bodged as well, so if the "indication" leading to the crew shutting down an engine was, for example, excess engine vibration, then I think this occurance starts to become a whole lot more relevant/newsworthy.
13 Apr 2009
UK
Perhaps. But let us not discount the fact these aircraft have been sat on the ground for nearly 18 months. It's not even the same as the current fleets which may fly a circuit once a week, they weren't allowed off the ground at all. How much can be attributed to the fact they've been sat on the ground after barely flying before they were grounded? Could these just be a few teething/shake-down style issues that would have cropped up anyway?
12 Jul 2007
Stoke/Norfolk
From the info I'd read it was a hyd indication issue initially, then a fuel flow issue to the LH engine needing a shutdown for safety. Considering it's just left realitive long term storage I'd say these thing (sticky valves etc) will be more common now than on an aircraft that's flying everyday, just like a stored car will suffer.
Man of Honour
5 Jun 2003
Falling...
I hadn't been aware of their issues! Wow.
I haven't flown Ryanair in over a dozen years and certainly never plan on flying with them, this has cemented my feelings on the matter.
14 Jan 2018
Hampshire
It's not a Ryanair plane. Actually shocking though, the history of the 737 max does not inspire confidence in Boeing.
Man of Honour
5 Jun 2003
Falling...
No I appreciate that. I just don't like Ryanair find it horrible experience! I've flown on them half a dozen times and point blank refuse now.
I hadn't appreciated how much of an issue this plane was though. You're right it does make you concerned, I thought Boeing were generally good? So what happened in this plane? Cheap procurement/fit out/testing?
18 Apr 2020
That looks horrendous, thankfully didn't happen at 35k feet and no-one was killed. As it's only a couple of months old then it can't be a maintenance issue so most likely a build issue and hopefully not a design fault. I'm a big believer in keeping my seatbelt on at all times when flying although if you were in the seat that got ripped out then that's not going to help. Looks like it's some sort of unused door that failed.
18 Feb 2007
London
Yeah it seems its an area used as an emergency exit by airlines, in this case Alaska airlines do not, quite unbelievable no one was sitting there.
