That's them!
These are the ones. https://www.costco.co.uk/c/Kirkland-Signature-Ultra-Plush-Microfibre-Towels-36-Pack/p/713160 They used to be £13 plus vat and i think you can get them on offer at times. They are pretty great for everything. I have loads round the house and in the garage.
Looking for a pump sprayer and foamer. Is this one any good?
Foaming Pump Sprayer 2-Litre | It Can Foam Now Too
The ultimate Foaming Pump Sprayer from decanting Citrus Power Bug & Grime Remover pre-wash to mixing up the correct dilution of Verso All Purpose Cleaner, the Foaming Pressure Sprayer is the ideal detailing accessory for getting the most from your dilutable, and 5-litre trade-size, detailing...www.autofinesse.com
It OOS but with 10/15% vouchers floating about I could wait. Anything similar that this one has copied and shipped over from abroad.
Nice one. Been looking for something like this also to go down the Rinseless route and can have them for different panels.
For what purpose? Is it to do the entire car with it? If so, you’ll be doing a lot of, ahem, pumping.
Speaking from experience
hold your horses !
im buying them for waterless wash
if you want to do Rinselss wash on exterior, use a dedicated sponge thing, never need to wash them !
£19.99 inc. Frustratingly they normally sell around £13 inc in store. Link looks like the same thing though, for sure.ah , yeah someone told me about Kirkland ones before
is that 19.99 + VAT ?
as you can get them from here (without all the membership added on)
The kirkland towels aren't *that* good. GP car care are doing big bags of fibreking mfs now.its ok found the answer £33 a year or online only at £15 a year
not worth it for me
ah well worth a look at, thanks guys
Last 5 wks of grime and time for a wash.
First time using Auto Finesse Aqua coat. It went on easy and the results are good. Thanks @Gilbert89, good gloss and beads well.
