Poll: Ryzen 7950X3D, 7900X3D, 7800X3D
Will you be purchasing the 7800X3D on the 6th?
  • Total voters
    191
  • Poll closed .
27 Jan 2003
Chesterfield, UK
I'm not convinced tbf, most people don't even think PBO is overclocking so probably had it running at +200Mhz. :cry:
I have two cores at +3 with 200Mhz if I want to pass stability in AVX2. It's a shame that there is not a one size fits all 'test' for tuning CO would make lives a lot easier.
Still, this is 100% stable in everything. SHA3, AVX2, Football Manager 2024, y cruncher 00-x86, Karhu 8+ hours. Karhu is about 334.5MB average.
I saw your WRTS at 1 on oc.net, I might try lowering mine to see if I can get anymore from it.
I didn’t think you could increase the boost on the 7950X3D? I thought it was locked unlike the 5900X
Caporegime
12 Jul 2007
United Kingdom
You can increase the frequency on the cache CCD via negative curve optimiser. On the frequency CCD you can increase frequency via both negative curve optimiser and PBO overclock up to a total of 200Mhz, eg 5.7Ghz to 5.9Ghz, dependent on temperature and power headroom.
You can't do a (traditional) all core overclock on the 7950X3D, you can however overclock via BCLK.
27 Jan 2003
Chesterfield, UK
Cheers for that. I will have a look
22 Oct 2004
Very nice build Nath. Early days but how you getting on with the gigabyte board. I used to have one in a 4790k build before I went Asus boards and thought it was really well made.
19 Jan 2012
Thanks very much, yeah. It was late by the time I'd got Windows reinstalled, had a X570 Gigabyte board previously so bios settings much the same, would have liked a debug code, but it has the error leds instead.
Updated to the latest bios aswell, which now has a white theme to match the motherboard.
It's a shame there isn't more choice out there at the moment for the white boards. But I'm very happy so far.
3 May 2021
Italy
Everything except the GPU arrived, this weekend I'll likely post asking for some assembly advice.
Is 2g of Thermal Grizzly Kryonaut enough to a 7950X3D?
Caporegime
12 Jul 2007
United Kingdom
Plenty. Just spread it with a thin layer of paste out over the CPU lid yourself, then put a small pea sized dot in the middle and stick your cooler on.
8 Nov 2006
Scotland
At this point I’m guessing I should just wait for the new chips vs a 7800x3d?
Could wait to see if the 7800x3D drops in price a bit more, but probably not if AMD stagger 3D cache release again and it doesn't come to late 2024/early 2025. 7800x3Ds can be picked up at really good prices just now, it's the motherboards that can still be a rip off. That alone means it might be best waiting for the next line of overpriced motherboards to see if prices of current drop a bit.
I've been testing what is needed for tCL32 @ 8000 with my memory and it seems to be around 1.75v :eek: Thank goodness for watercooling!
Man of Honour
21 Nov 2004
I have a basket of this currently:
7800x3d
Corsair vengeance 32GB 6000CL30
Corsair TM30 paste
ASU’s TUF gaming B650plus
Coolermaster Masterliquid 240
SN850X 2TB
Does that work?
