Same argument could be said with frame caps but people never mention that - aka i could say why buy a 4090 if you use a frame cap. But just cause you don't run it at full performance all the time doesn't mean it was a waste
Exactly. The Genious should have bought at weaker GPU!A frame cap is totally different,
For example if you had a very demanding game that ran at 50fps and you had a 60fps frame cap you would still get 50fps
Where if you put in a power limit you would get less then 50fps
Because it's like 4-5fps average drop, max whilst the GPU runs cooler, quieter and as a result the rest of the system runs cooler and quieter not having to spool up the case fans higher as a result when gaming. Lower model cards would be considerably more laboured doing the same thing and thus struggling to maintain frames. A 4090 does not have this issue.Why buy a 4090 if you're going to just limit it to 72% ?
A 4090 makes power limiting totally trivial, it's merely done to generate less heat and noise as the fps drop is so low it's irrelevant. I run mine at 80% PL at all times for example just because I can, under 200 watts draw in non RT games, under 260 watts draw in RT games whilst the fans spin at ~1200-1700rpm vs stock PL taking the fans to 2200rpm+ and 450 watts draw which is a waste of power and a waste of efficiency. 4090s are considerably over-specced on power limits.
Also what the others have said.
On the flipside all native PC games are framecapped by Gsync at 139fps as I want 100fps minimum for PC games where I am moving the camera with a mouse for maximum fluidity.
G-sync doesn't do that on my system, Like just now i loaded up Bioshock remastered and the game running at well over 600fps unless i enable v-sync or enter a max framecap and i have a G-sync monitor with gsync enabled
Did you enter the 139fps under the Max Frame Rate in the Nvidia control panel ?
I just find another setting in the nvidia control panel
Preferred refresh rate (Asus Computer Inc ROG PG35V) where i can choose "Appication controlled or Highest available "
Wonder if they've managed to reimplement their legendary stuttering with ReSTIR GL.
That's pretty much on the devs too.Wonder if they've managed to reimplement their legendary stuttering with ReSTIR GL.
Shame it's not much more than a tech demo yet, hope they fill it with content soonIf you haven't seen it yet I suggest checking out Grey Zone. It's a game that finally shows what Unreal 5 can do outside of a canned demo.
