Sudden GPU temp spike on 4070 TI
1 Oct 2020
Hey there,
Been happily running a Asus TUF 4070 TI in my system.
Today, I started a new game for the first time (the rumoured crappy-but-so-crappy-it's-good "Wanted: Dead"), and something occured that I've never seen before: my GPU, for just a few seconds, instantly shot to 83 degrees, fans on full blast, instantly thermal throttling. It's the first time I've ever seen this behavior, and something that i cannot replicate again on subsequent launches.
I thought my card might be broken, so I ran the following tests:
  • OCCT 3D standard test: 78-79 degrees, 30 minutes, no errors
  • Furmark: 75 degrees
  • Superposition benchmarks: 3 or 4 runs, nothing out of the ordinary
  • Cyberpunk Path Tracing: Let it sit for 30 minutes on a busy intersection, 99% GPU usage: 70-72 degrees
  • Alan Wake Path Tracing: Let it sit in the forest section of the game for 15 minutes: 99% GPU usage, 70-72 degrees
What can be the cause of this weird spike? Am I being too concerned?
Man of Honour
22 Jun 2006
A few possibilities:
- a menu or load screen that had no frame limit applied to it
- something that used the GPU for compute
- some kind of bug with a DRM
OP
1 Oct 2020
Forcing vsync in nvidia panel, always, so it should not go overboard.
Do you think this is cause for concern? I cannot replicate, all the other tests come up okay, and I've just let it sit for 30 minutes in Cyberpunk, full path tracing, 99% usage, hovering about 70 degrees.
I've also checked the delta between my temp and hot spot temp during a run of Superposition Benchmark, and that is okay as well (15 degrees delta, same results as I had half a year ago).
Ease this troubled mind, please :)
11 Jan 2021
just go in nvidia control panel and ,anually set a max fps, should stop it happening anywhere else as i thinkl the same thing is what was killing gpus when new world came out
