Picked up a bobo m3 pro but not sure I can sick it. It feels like it preventing the hmd from sitting low enough and flush enough on my face. The hmd is technically fine for position but the feeling is just weird. Anyone had a similar experience? Do you get used to it?
I've ordered a kiwi in the mean time to compare, the non-battery one. Very pricey compared to bobo.
You can have a pretty good range of fit with the M3 pro depending how far forward or backward you have the headset sidearms slid into the M3 strap runners.
You have three main options with a halo strap.
1. Go full halo, with just the halo strap touching your head and the HMD floating in front of your eyes, quest pro stylie. You can even remove the interface to get it closer to your eyes.
2. Halo/elite mix, where the both the halo strap and facial interface are touching your head. You can get a large range of adjustment of pressure shared by the interface and halo strap. For me, the sweet spot is 50/50. I have the interface and halo set to the same distance from my head, so the pressure is shared equally which reduces it for a given area.
3. Full elite style, where the HMD is fully rearward in the halo strap side rails, the forehead cushion is removed, and only the facial interface is touching your head.
You could even extend the depth of the facial interface if your head is shaped like megamind.
