Windows 11 is garbage
12 Apr 2007
Yeah, it's a bit silly going public about issues you have with what's essentially a 'beta' build....lol
Win11 (alpha) is rock solid in my experience...my only bug bears (excuse the pun) are the UI changes that sometimes don't make sense (to me) and result in far more clicks to do what I used to be able to do blindfolded in win10.
Man of Honour
22 Jun 2006
Same, the OS works fine, but for productivity it is more awkward to use for no good reason.
12 Apr 2007
Take your pick it is either incompetence or they want everyone having to run hardware which support TPM and that isn't for any reasons favourable to the end user...
It's not even just TPM...my 2ndary PC is an i5 6600k and can quite easily run win11, and the mobo has the correct version of TPM..but no... only 8th gen intel or later is supported.
When support for win10 stops i'll have to make a choice for that machine.. I'll have to run it sandboxed/offline if i want to play games in windows, or I'll be forced to put linux mint on it or something. It has an AMD graphics card, which I hear is better than Invidia for gaming in linux environments..so I'll see what's what win10 stops getting security updates I guess.
Man of Honour
22 Jun 2006
If you have secure boot and TPM enabled then it should install and activate fine on a 6th gen PC. I did it recently and all that happened was a popup asked me to confirm that I'm running a CPU that is not supported. When I tried it without secure boot, the installer wouldn't start.
12 Apr 2007
a plus for win11, bluetooth support, specificaly for x-box game pad is great...it can be troublesome on win 10, when using the same pad and try to use it between systems.
Man of Honour
13 Oct 2006
Something I hate with Windows 11 is the repeated aborted attempts at transparent blurred window backgrounds and quickly obsoleting old methods, breaking the original DWM method and a absolutely awful implementation using Mica material: https://learn.microsoft.com/en-us/windows/apps/desktop/modernize/apply-mica-win32 which is a cluster **** of different approaches rather than just fix and/or background override it via the original DWM approach.
Man of Honour
13 Oct 2006
Windows 11 adoption rates are still really poor and it seems W10 has gone UP as people have been rolling back from 11 on new PCs. I think it's safe to say it has been a flop at this point
The changes really are terrible and they seem to be doubling down on stupid :(
How they've not gone back and prioritised ripping out that worst possible take on an Android/Apple launcher for a Start Menu and done better I don't know.
10 Jul 2010
Windows 10 EOL support should be interesting, as there's going to be a larger percentage of 10 users than 11 users who might not have up-to-date systems - unless you're willing to cough up some money, that is.
22 Nov 2006
It will just end up sticking around and being unofficially supported, especially in the gaming community. Which is what happened with windows 7.
Also, pay for window lol? Who does that.
10 Jul 2010
Microsoft is ending support for Windows 10 on October 14th, 2025, and you’ll need to pay yearly if you want to continue using the operating system securely. Microsoft will offer Extended Security Updates (ESU) for Windows 10 users, with pricing starting at $61 for the first year.
Microsoft reveals how much businesses will have to pay to keep using Windows 10 securely - The Verge
12 Apr 2007
As has always happened, many will simply stop updating it.
Yeah, and then further down the line have to pay an eye watering amount of money for a specialist to come in and migrate it when it breaks..
This is the way.
Win11 is great apart from the UI. Microsoft could just do someting really easy like a legacy skin or theme, so you could choose win10 skin, or Xp skin etc.
22 Nov 2006
This is the way.
Why would it break. As long as it's isolated from outside threats it's fine.
