- 4 Feb 2011
- If anyone wants my 5% code PM me hopefully it works on other accounts for anyone who actually wants to buy one ASAP
you need the USB-C connection to support DP Alt mode (for video) AND power delivery of whatever your laptop requires to charge/run it. that's one featureAh damn that sucks, I nearly ordered it as well! I take it none of the Alienware oleds offer this?
So for future reference I need a monitor with USB-C port with DP alt mode in order to be a one stop place to plug my keyboard/mouse for use with either the pc or work laptop? As I stayed above I don't need to use both pc and laptop at the same time, while having the ease of only one cable to plug in. From my limited understanding then, if there is no KVM switch the USB connections only work with whatever is connected to the upstream? It's the KVm that allows the laptop to work when plugging into the usb-c?
when did you order?Mine arrived yesterday and I have just dropped it onto my desk 40 minutes ago and run a couple of HDR 4K videos.
First impressions are excellent but need to work with it come more. My first curved screen but seems to be ok so far I think.
No obvious issues so far.
That is very helpful thank you. Do you know of any current 4k OLEDS that would facilitate this? Seems strange its not on the Dell one.you need the USB-C connection to support DP Alt mode (for video) AND power delivery of whatever your laptop requires to charge/run it. that's one feature
then the other would be a KVM switch which allows you to plug in a single keyboard and mouse to the monitor itself, and have that control two different connected systems to that screen. usually those systems would be connected to the monitor either via that USB-C, or maybe a separate USB-C data connection or a USB normal connection. some of those KVM switches even allow intelligent and auto switching etc, it's quite a common feature nowadays
The MSI MPG321URX and Asus ROG Swift PG32UCDM doThat is very helpful thank you. Do you know of any current 4k OLEDS that would facilitate this? Seems strange it’s not on the Dell one.
Will check these out, thanks for your adviceThe MSI MPG321URX and Asus ROG Swift PG32UCDM do
The asus one does look nice though!You can just buy a separate dock / kvm to achieve the same thing - would be much cheaper than the extra £300+ for those models.
Search the thread. Mentioned several timesMine has shipped early and should arrive tomorrow. Very excited. I just hope UPS can get it here in one piece.
What are the best settings to use when I get it up and running?
If you mean the 32" Dell, then here you go:Mine has shipped early and should arrive tomorrow. Very excited. I just hope UPS can get it here in one piece.
So, I have the 27” but from what I’ve seen most of the settings seem universal. I have sRGB set in creator mode and the gamma set to 2.2. I have both the brightness and contrast at the default 75. HDR on the monitor is set to Peak 1000 and turned off within Windows.
I loaded BG3 in SDR and the image was very dark. Am I missing something?
This is my first OLED and HDR panel so I’m wondering if I’m just not used to it, having used a TN panel for the last 6 years.
