**DGM 27" LED IPS 2560x1440 ONLY £319.99 Inc. VAT (PRE-ORDER PRICE ONLY)!!**
4 Jul 2004
LDN
Does the DGM have any swivel / rotating capabilities? I have a dell u2711 but can only height adjust. Cant find any evidence that it does? Thinking of pairing it with my u2711
7 Dec 2009
Man of Honour
12 Jan 2003
UK
If there's no scaler then if you input a non native resolution it should just automatically fill the screnen. So an HDMI 1920 x 1080 input will be stretched to fill the screen. Since the screen is 16:9 aspect it won't be a problem. Where there are issues with a lack of scalers is if you were inputting non-native aspect ratios like 1280 x 1024, or 1920 x 1200. They would be stretched out of proportions. There's no option to maintain the source aspect ratio and have black bars, and no option to map pixels 1 to 1
20 May 2011
Aberdeen, Scotland
Hmm... as I'm currently returning my crossover for issues, this may affect whether I get a refund or a replacement.
1.) Is there an OSD for colour management?
2.) Can we have a spec sheet? I've heard it uses Samsung panels, you sure it's LG A+?
It's nice we can try it out for 14 days... the main reason I went for the Korean models is because of the 'pixel perfect' versions.
Final question: Can you tell us exactly what the difference is between A+ and A-? We all know about the tinting with Dell's and apple ACD's, so it can't be purely fault levels, can it?
1 Oct 2011
This monitor is an OEM of the Crossover 2720MDP Gold LED with the Component input, 1x HDMI and the Optical output removed. Good offer from OCUK because DGM actually raised the price to £350 as well as offering only 1 yr warranty AND their support model is not exactly your typical UK's. DGM seemingly only sold 3 units.
30 Jun 2006
Horsham
