First Water Project: The Mad Titan
5 Mar 2014
Southampton
Dom is getting boring IMO.
I would get this
5 Mar 2014
Southampton
I mean that they are developed for Z170 so there are others that would perform better no doubt?
I am still deciding between Dom Plat, Kingston and gSkill... Not sure yet... :)
Cheers
Ben
nah it's just marketing gimmick. All ram, at the same speed and cas latency should give equal performance.
The differences come in overclocking ability, the ability to run high mhz, the ability to run at low cas, stuffs like that. Even cheap basic no heatsink corsair ram @ 3000Mhz 16-16-16-35 should give equal performance compared to a much more higher class Corsair Dom @3000Mhz 16-16-16-35.
OP
9 Aug 2015
Cambridgeshire
I thought there were differences with the actual IC's used?
Thanks for the info, much appreciated! Basically I need to weigh up aesthetics and performance then! :)
Cheers!
Ben
