This is probably because you using High performance power setting... a lot of people forget this also disables core parking
Lol ok so there's me hacking the registery and all I had to do was the above
Do me a favour plox,
start up battlefield 3 multiplayer, 64 man server, join.
Once in game press the console key ( ` that one) the one to the left of 1.
Then type
Render.perfoverlayvisible 1
Hit enter.
Now drive out of base a few yards and take a screenshot and show me the graph. Do one with settings at default and this core parking trick you talk about.
You shouldn't be getting stuttering with an i7. What is all this talk of core parking? I don't remember having to do anything like this when i was on Windows 7 to get smooth performance in Battlefield 3. The game is not demanding at all any more, even at 1440p.
I know I shouldn't be getting it - my i7 920 @ 3.6 did not experience it at all (although the average FPS there was on the whole, lower than my new setup at stock, when using the in-game FPS counter).
This "core-parking" thing is something I have frequently read about with regard to SB, so I was assuming it is the cause. I still need to play enough different maps and scenarios to be sure about stutter - and to be fair, it is very minor stutter, not a lag-fest but more like jitters in certain scenarios where the FPS seems to drop right down (to 44 or so) and stay there for a few seconds.
Do what LtMatt said and enable the in game monitor as this will show you how your CPU & GPU work together.
Matt,
Just out of interest, does that overlay show us bottlenecks?
Just gave it a go and mine's the opposite, cpu bar is higher than gpu.
Would make sense i assume seeing as my gpu is the limiting factor in my system.
No mate im on balanced power setting. Never touch any of those things other than to stop my hard drivers turning off after 30 minutes.
Interesting, is it only the hard drive setting you defo change? Dont touch PCI or CPU?
I always used High performance so CPU min/max power state was always 100%.
Going to give Balanced a try for couple days. See if I notice any change from cpu min 5% and max 100%
Yer setting the CPU on the power to min/max 100% stops the cpu cores switching off.
Why would you want to turn off the power saving functions when it does not affect performance.
Never knew this always thought having cpu min 100% and max 100% would boost performance lol
Seeing from your tests alone I know this isn't the case.
Leave the high performance at 100%, turning any power saving functions in in windows isn't worth it for gaming systems.
Wrong
No you wrong lol
That's just reading the Reg setting and that's it.. Because the Reg setting is still enabled the program is saying there parked.
Setting the min/max at 100% stops the cpu from hitting low power state and dropping into core parking.
I never touched the Reg and I never get cores parked.
Then why would windows have a seperate setting for cores parking in registry if min/max 100% stops the cores parking anyway. So far your post is the very first i've heard of it.
http://bitsum.com/about_cpu_core_parking.php
