Highest Revving Road Car?
Man of Honour
21 Feb 2006
The 997 GT3 MK2 goes to 8500rpm, my 996 MK2 went to 8200 in first 4 gears, which isn't bad for a 3.6L 6 cylinder and my RS4 goes to 8000rpm which is pretty good for a 4.2L V8. E46 M3's went to 8000rpm.
13 Jan 2004
Well, the USA S2000 was a 2.2 liter iirc, and doesn't rev as high as the uk/jdm ones. A bit of googling suggests that the RX8 rev limiter is 9.5k, which will be the highest of any standard road car (excluding bike engines etc)
The US AP2 model is a 2.2 litre with ~8k rev limiter.
The US still got 9k revving AP1 models however.
18 Oct 2002
F20C equiped Honda S2000 revs through to 9250 RPM, or, if you are me downshifting into 3rd on the back straight for the quick left right at bedford, just shy of 11500 rpm.
Story goes...
Shifting down, forgot to check how much speed I'd scrubbed off, shifted into 3rd at just over 110 mph (limiter is ~93) car sounded like a very angry bee.... got through the corner... tapped the throttle and all seemed ok, took the next two straights short shifting at 7k, and then just went back up to max revs as previous. That was about 6 months ago now and it hasn't missed a beat.
8 Mar 2006
Near Winchester
I've seen a Tipo making a nasty racket after someone missed 4th and got 2nd at about 80mph. Turns out the fan blades on the alternator had spread out and were catching something, engine was fine.
I was thinking stuff with no limiter that will naturally get up there, would prolly have to be a safe engine.
